t10bender
Dec 04, 2022Aspirant
Nighthawk AX1800 (RAX10) wifi router
My current set up: Nighthawk AX1800 (RAX10) wifi router, connected to a Netgear wifi cable modem. If I want to add the Mesh 6 system, do i need to: replace the Mesh 6 router with the existing RAX10 ...
michaelkenward
Dec 06, 2022Guru - Experienced User
t10bender wrote:
So here's what I have:
Netgear Cable Modem
Sigh.
plemans wrote:
You put you have a RAX10 and a cable modem/router device. What cable modem/router is it?
t10bender
Dec 14, 2022Aspirant
CM1000-100NAS
- t10benderDec 14, 2022Aspirant
Sorry. Some of us are construction workers and not computer wizards. Thus........
- michaelkenwardDec 15, 2022Guru - Experienced User
Doubtless your trade has its own set of tools.
Telling someone in your trade that you used a "digger" would probably elicit questions about which digger. There's more than one of them out there.
t10bender wrote:
CM1000-100NAS
OK. That's a standard cable modem only device. Nothing of a router nature to get in the way.
- plemansDec 15, 2022Guru - Experienced User
The MR60 and the RAX10 are pretty similar in performance. Using both would just add extra ssid's/interference.
What I'd do is go
CM1000---Mr60----->satellites
You can add the extra satellite to the system as needed. I'd hold onto the other MR60 (router) that you have for a backup in case the main one fails. That way you don't have a bunch of useless satellites as they need the controlling router.
I'd probably sell the RAX10 unless you need it for something else.
- t10benderDec 16, 2022Aspirant
Thank you. I had the same thought. Which I may do today.
Yesterday, I did get the second satellite to sync. As long as it was in the same room. I moved it to another outlook in view of the Mr60 and the other satellite, it'd sync. I moved it to where I want it to sit, pretty much unobstructed from the other satellite, and it won't sync up???
