Rod_Horning
Apr 28, 2022Tutor
Nighthawk AX2400 RAX30 Backup Blocked due to .cfg file extention
Windows 10 RAX30 Firmware: V1.0.4.66_1 Trying to backup the configuration of the router. ADVANCED -> Backup Settings Click Back up Windows blocks the backup with the message ....cfg was blocke...
Apr 29, 2022Guru - Experienced User
Have you tried it on a different pc? Something in your own windows or browser settings is giving you the alert
Rod_Horning
Apr 29, 2022Tutor
I haven't. Thanks for the suggestion.
