Psyonic
Aug 10, 2022Aspirant
Nighthawk AX2400 (RAX30) not forwarding port 8123
My old N600 (which has been great for the last 12 years) decided that yesterday was it's last day in my service (she died) so I brought a Nighthawk AX2400. I have a Home Assistant server running ...
michaelkenward
Aug 10, 2022Guru - Experienced User
I'm a bit puzzled by where the internal IP address in there came from.
I wouldn't expect to see 192.168.0.1.
By default your router likes to squat on 192.168.1.1.
Something carried over from your anonymous N600 device?
Psyonic
Aug 11, 2022Aspirant
michaelkenwardOh, I should read better 🤣
192.168.0.1 is the address I've always given my routers, I change it from default coz most of my devices have static IPs... Just a thing in my head from setting up Linux PC's as modem/LAN/firewalls from back in the dial-up days. Not wise these days?? Didn't think it mattered? But I haven't done much networking since those days
- michaelkenwardAug 11, 2022Guru - Experienced User
Makes sense. I was just a bit puzzled by the "out of the ordinary" setting.
That IP address has sometimes revealed extra devices on the network that get in the way of the router.
I also fix IP addresses on various devices on the network.
- PsyonicAug 11, 2022Aspirant
Thanks man...
Any thoughts on why 8123 would not be aloud to be open? makes no sense to me and it's worked on other routers
