LadyAlf
Jan 27, 2025Aspirant
Nighthawk AX2400 wi-fi password incorrect
I have had this router for 3 years and all of a sudden the password for my 2.4ghz is incorrect. I can log into the 5G but not the 2.4, and several devices rely on the 2.4. I logged into the app and ve...
LadyAlf
Jan 28, 2025Aspirant
How do I log into the browser? I have the Nighthawk app. What is smart connect?
Jan 29, 2025Guru - Experienced User
You log into the browser using its ip address.
Smart connect combines the ssids for 2.4ghz/5ghz into a single ssid. In that mode, they don't show up as separate but the same network. It allows devices to bandsteer between the 2 bands as needed.
- LadyAlfJan 29, 2025AspirantOkay, I assume I can get the IP address from the Nighthawk app? And no, I do not have smart connection enabled, I have several devices that cannot connect to 5G and require a separate 2.4 connection.
- michaelkenwardJan 29, 2025Guru - Experienced User
LadyAlf wrote:
Okay, I assume I can get the IP address from the Nighthawk app? And no, I do not have smart connection enabled, I have several devices that cannot connect to 5G and require a separate 2.4 connection.Not sure that I follow all of this discussion. If you want to get into the router to change wifi settings, most are outside the app's control. Use a web browser and the graphical user interface (GUI).
You can find the IP address in the app: check the Details button. Most Netgear routers sit on 192.168.1.1.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
Just another user with time on their hands.
- LadyAlfJan 29, 2025AspirantGot it.
So my phone and another device are telling me that the password to my 2.4 connection is incorrect even though it is correct in the app, I haven’t changed it, and have numerous other devices connected to it. But my phone can connect to the 5G which is the same password. Doesn’t make any sense. My thermostat all of a sudden was disconnected and I cannot reconnect it. I would think it was the thermostat but since my cell phone gets the same error, that tells me that it’s the router.
