kboasso
May 13, 2024Follower
Nighthawk AX2400 WiFi 6 Router (RAX29) with Starlink Standard Actuated
Using Netgear Nighthawk AX2400 WiFi 6 Router (RAX29) for home; all is good. Moved to a location where Starlink is the best-available internet service; purchased a Standard Actuated Kit (which includ...
michaelkenward
May 14, 2024Guru - Experienced User
I can't find anything official from Netgear. If Starlink can't help you to use third party devices on its network, there's quite a lot of stuff around here.
Search - NETGEAR Communities – starlink
Sniff around and you should find something helpful.
