kboasso
May 13, 2024Follower
Nighthawk AX2400 WiFi 6 Router (RAX29) with Starlink Standard Actuated
Using Netgear Nighthawk AX2400 WiFi 6 Router (RAX29) for home; all is good. Moved to a location where Starlink is the best-available internet service; purchased a Standard Actuated Kit (which includ...
May 14, 2024Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
kboasso wrote:
Using Netgear Nighthawk AX2400 WiFi 6 Router (RAX29) for home; all is good. Moved to a location where Starlink is the best-available internet service; purchased a Standard Actuated Kit (which includes a rectangular dish & a router) and an ethernet adapter for the extra port. I want a single local wifi network that leverages both routers (for extended coverage but with a single presence & connection/log-in protocol).
Can this be done without buying additional equipment? If so, how? Connections, configurations & complications will be greatly appreciated. Thanks!
