Jaspo
Sep 11, 2020Aspirant
Nighthawk AX3000 factory reset sometimes defaults to different SSID & pw
It works great for a few weeks but then looses it's internet connection and all settings are gone. When I try to connect to it either with the Nighthawk app or a browser using routerlogin.net it prom...
Jaspo
Sep 17, 2020Aspirant
Thanks Christian. I contacted their support team when the problem first happened and was able to get the problem resolved, or so I thought at that time. The router has now done this same thing 3 times since I have had it. Works for a few weeks or up to a month and then looses all it's settings.I already did the 'replace my defective product' and have a ticket case # but no one has replied in 10 days. I purchased it June 1st, I'm now over 2 weeks past the end of free tech support.
Christian_R
Sep 18, 2020NETGEAR Employee Retired
Hi Jaspo,
May you send me a private message with your latest case number and email address. I'll see if support can follow up.
Christian
