MoseJanitor
Jul 29, 2020Follower
Nighthawk ax3000
Hello, I updated my firmware to the most recent today (V1.0.3.80_1.0.1) and immediately following this update my routers 2.4 & 5ghz bands no longer showed up on any of my devices. I tried the basic tu...
Jul 30, 2020Guru - Experienced User
the wifi 2.4ghz/5ghz lights are on?
Just checking to see if the wifi on/off button got hit. You can push and hold it for 2 seconds to turn it on/off.
You've tried a full factory reset? Pushing and holding reset for 7-15 seconds?
If so, I'd actually try reinstalling that same firmware over an ethernet conenction, reset the router, and then try setup again.
If it doesn't work, you could try downgrading to the older version. maybe the one you're on introducted a bug/issue.
Make sure to update/downgrade firmware over a hardwired connection for best results.
