eskie
Dec 06, 2020Follower
Nighthawk AX4 4-Stream AX3000 Wi-Fi 6 Router
just a quick note on this Router which is a RAX35 and noticed it has no USB3 port on it and the box it came in shows a USB3 port on the back and also in writing on the label ,so wondering if it was replaced from this original box or does this model not have one ...thanks
1 Reply
The RAX40 has a usb 3.0 port
The RAX35 doesn't have a usb port.
they're literally the same router with only the RAX35 doesn't have the port.
I looked up the RAX35's product data sheet and manual and nothing shows a usb port. Same with the website.
https://www.netgear.com/home/wifi/routers/rax35
Not sure if you got a funny box/wrong box, wrong device, or what happened.
