ScottReed
Jun 15, 2023Aspirant
Nighthawk AX4 AX3000 incorrect SSID, incorrect default password
I brought up a Starlink network yesterday using a Nighthawk AX3000 router. It was flaky with security errors but worked flawlessly after a hard reset. Good connection, good speed, loved it. SSID= def...
ScottReed
Jun 18, 2023Aspirant
Starlink network - Several years ago, SpaceX/Starlink, under the leadership of Elon Musk, rolled out several thousand low-orbit satellites to support global Internet at affordable prices. Using a supplied Starlink satellite dish and router speeds of 200 mbps can be achieved for residential Internet where other alternatives for fast internet do not exist (rural customers).
The Starlink router is the primary router on a Starlink network. In my case, the Netgear RAX35 router is configured as an AP inside my home. The Starlink router sits outside next to the Starlink dish in a weather-tight cabinet. A Ubiquiti Litebeam wireless bridge connects the two devices on the "Starlink network".
The firmware on the RAX35 has been updated to the newest firmware version.
The RAX35 default password was "shinycomet890". After a hard reset, the password that I defined should have been replaced with the default password. This did not happen.
The SSID on the RAX35, which I have never changed, was being broadcast as "netgear53" instead of the default "netgear76" with who knows what for a password?
Working with a senior Netgear support person, we finally accessed the router using the RAX35 IP address of 192.168.1.1. The reset restored this IP address to default, turned off the AP config and botched the SSID to netgear53. No one knows where netgear53 was coming from but it was preventing access to the RAX35 by SSID. Netgear still does not have a clue regarding netgear53 nor do they know why the SSID was changed without human intervention. The default netgear76 is back, netgear53 is gone, and everything is back to normal.
Perhaps this problem was caused by my resetting the RAX35 in order to eliminate multiple security errors that were plaguing the network. The reset did eliminate the errors but it also placed two routers on the network with both performing DHCP and both having the same IP address. A situation destined for failure.
This all has been repaired with no explanation from Netgear as to why this happened. This case is being closed. Thank you for your input!
Kitsap
Jun 18, 2023Master
ScottReed wrote:Starlink network - Several years ago, SpaceX/Starlink, under the leadership of Elon Musk, rolled out several thousand low-orbit satellites to support global Internet at affordable prices. Using a supplied Starlink satellite dish and router speeds of 200 mbps can be achieved for residential Internet where other alternatives for fast internet do not exist (rural customers).
Interesting story. Thank you for the narrative. One plausible explanation I can think of, the initial firmware default reset process did not fully execute and it took more than one pass to complete. As a general practice, it is good to perform the default reset with no external connections to the router, let it run for a few minutes, disconnect/connect the power cord and repeat the process.
