KT62
Sep 30, 2020Guide
Nighthawk AX4 AX3000 WiFi constantly going OFFLINE
PURCHASE: March 2020 HARDWARE: Nighthawk AX4 AX3000 (RAX35) FIRMWARE: V1.0.3.80_1.0.1 MODEM: Comcast/Xfinity in bridge-mode NOTE: Ethernet connected devices will sometimes maintain internet acc...
- Oct 01, 2020Should have searched the community forums regarding this - there are at least 5 other threads discussing this widespread issue plaguing the RAX40 and so many other RAX products due to faulty firmware. You have to revert to the previous version until Netgear fix the bugs in their firmware. Who knows when they will because they are so slack with support.
Oct 01, 2020Guru - Experienced User
When the wifi "goes out" does it say "connected, no internet". Does it not connect at all even though it can see its broadcasting? does it not see the router broadcasting at all?
You've had this for a while, did this just start?
have you tried a factory reset and reinstall? there's been quite a few firmware changes on the AX devices and they've responded well to factory resets and reinstalls.
