ctclone3211
Jul 24, 2019Tutor
Nighthawk ax4 Chage prior WiFI SSID
Can't get to my WiFi on the new router because the prior router SSID has not been transferred to the new one. How to get online with the Nighthawk so I can update the new on with the correct SSID an...
- Jul 25, 2019
What modem sits in front of your router.
michaelkenward
Jul 25, 2019Guru - Experienced User
Not sure what that means, but you can change the SSID to your new router to anything you like. You can also use the default (factory) SSID and password on the label on the thing.
It might help if you said what the model number is for your new "AX4" device.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
Read the stiff on how to change the basic wifi settings.
ctclone3211
Jul 25, 2019Tutor
Sorry mis-stated the issue. Can not get through the setup with the phone app. Can not get to the web address for the router. It is 192.168.1.1 but will not register on my desktop. My laptop attached to the router was able to get there but loss internet connection. Currently lost as to how to get there. Have tried Netgear but 1st level did not get the job done. The router does show on my list of devices attached.
- michaelkenwardJul 25, 2019Guru - Experienced User
- ctclone3211Jul 25, 2019Tutor
After spending many hours with Netgear, it was determined that I had a defective router and needed to return it from where it was purchased. Thanks for your responses but this case is closed
