1appleluvr
Nov 24, 2019Guide
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connec...
Christian_R
Nov 29, 2019NETGEAR Employee Retired
Hello 1appleluvr,
Welcome to the community! I'd like for our support to get in contact with you for further assistance. Please send me a message with your contact info and serial number.
Thanks,
Christian
- 1appleluvrDec 01, 2019Guide
Private message Sent. I will update this post accordingly with any resolution as I receive it.
- 3RCFosterDec 16, 2019TutorHas this issue been resolved? I'm having the same problem with a new note 10+.🙄
- 1appleluvrDec 16, 2019Guide
I have not received a resolution from Netgear support.
The only solution that seems to work for me is to reset the router and start network settings from scratch again. I do this about once a month or so.
- 3RCFosterDec 16, 2019TutorThanks man. I'm having to do this daily. 🙄
- Jason_akersAug 23, 2021Aspirant
- michaelkenwardAug 23, 2021Guru - Experienced User
Possibly.
Did you miss out something?
- Jason_akersAug 24, 2021AspirantNo it just won’t work every light is lit up green on my router but it says couldn’t find DHCP when I try to connect
