1appleluvr
Nov 24, 2019Guide
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connec...
3RCFoster
Dec 16, 2019Tutor
Has this issue been resolved? I'm having the same problem with a new note 10+.🙄
1appleluvr
Dec 16, 2019Guide
I have not received a resolution from Netgear support.
The only solution that seems to work for me is to reset the router and start network settings from scratch again. I do this about once a month or so.
- 3RCFosterDec 16, 2019TutorThanks man. I'm having to do this daily. 🙄
- 1appleluvrDec 16, 2019Guide
If you have the same issue as me with your DHCP server, if you set the IP address of your device to a static IP and static DNS it worked for me. That would technically work but devices that I cannot set static IP addressess on would not be able to connect. Along with the fact that new devices temporarily trying to access my wifi would have to forego this tedious process just to connect, it is not acceptable from a brand and luxury product like Netgear is.
- 3RCFosterDec 16, 2019TutorNo it's not. I expected more from the Support side also. Thnx for the work around. 😉
