1appleluvr
Nov 24, 2019Guide
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connec...
1appleluvr
Dec 16, 2019Guide
If you have the same issue as me with your DHCP server, if you set the IP address of your device to a static IP and static DNS it worked for me. That would technically work but devices that I cannot set static IP addressess on would not be able to connect. Along with the fact that new devices temporarily trying to access my wifi would have to forego this tedious process just to connect, it is not acceptable from a brand and luxury product like Netgear is.
3RCFoster
Dec 16, 2019Tutor
No it's not. I expected more from the Support side also. Thnx for the work around. đ
- 1appleluvrDec 18, 2019Guide
Today I received a response from Netgear. They are refusing to provide me support for this issue on the sole basis that I did not purchase from an "authorized Netgear reseller". I purchased it online from a person who longer wanted the router.
Not exactly what I would call good customer service. Regardless of where someone purchases your product, support should be available. Bottom line is that I have not opened, altered or otherwise changed how the product functions so reseller or not, support should be a given.
I am dissapointed in Netgear. I will be forced to purchase my next router from a different manufacturer that cares enough to support all the products they produce rather than only the ones sold by resellers deemed "authorized".
In the meantime, if anyone has any actual solutions they would like to share, please do!
- michaelkenwardDec 19, 2019Guru - Experienced User
Unfortunately, that's not how these things work.You will find that other brands have similar rules. Check before you try something else.
In any case, "free" support is for only 90 days.Basically it is set-up support.
Your best bet is to persevere with this place by providing as much information as possible, with details of what you have done and where it goes wrong.
For a start, have you tried different firmware? Sadly, latest is not always greatest.
- ThomasPapeFeb 26, 2020Initiate
Hi guys. Just wantet to hear if anyone has any other ideas except for static IP and DNS for this issue. I'm having similar problems acros multiple devices using the wifi.
They seem to be connecting fine, but getting wrong ot no DHCP data. Usually rebooting the device or the router seems to fix it.
