1appleluvr
Nov 24, 2019Guide
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connec...
ccwbeliever
Aug 01, 2021Star
Hello all,
I recently purchased a Netgear AC1750 router to replace my local ISP router that I had been renting. Setting it up was fairly easy enough, but I noticed that when re-booting the router or if the power goes out for some reason, many devices on my network have trouble re-connecting. They appear to sit spinning waiting for an IP address to be assigned.
I have many "smart" devices connected to my network such as light switchs, light bulbs, outlets, TVs, "smart" speakers, etc. I have ~30+ devices all connected to the network. While I'm in IT software development for a living, I do not do hardware or infrastructure... so I'm by no means an expert in this area. Yet, I know enough to get myself into trouble... :-)
When the power goes out and all devices start scrambling to get re-connected, the router seems to have trouble dealing with the high-volume of traffic. Not sure if there is a setting somewhere that somehow throttles this or tells devices to refresh or something.. but, here's what seemed to solve my problem.
I simply went into the LAN setup page and assigned static IP addresses to all the devices in the home that are always here. Every light switch, outlet, lighbulb, smart TV, smart speaker, etc. is reserved its own IP address. Now when I re-boot the router, everyone goes to their spot and connections happen VERY fast. Seems to have resolved the issue for me.
Then when I connect something new like a laptop, smart phone, etc... not all of those are assigned and IP and the router seems to have an easier time of assigning just those few as needed. It's not doing it for every device every time I reboot or power or network hiccups for a brief moment.
Hope this helps someone.
Steve
michaelkenward
Aug 01, 2021Guru - Experienced User
That could be one of several devices. AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
- ccwbelieverAug 01, 2021Star
Howdy...
Yes, the Model of my AC1750 is R6400-100NAS
Thanks,
Steve
