1appleluvr
Nov 24, 2019Guide
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connec...
Jason_akers
Aug 23, 2021Aspirant
michaelkenward
Aug 23, 2021Guru - Experienced User
Possibly.
Did you miss out something?
- Jason_akersAug 24, 2021AspirantNo it just won’t work every light is lit up green on my router but it says couldn’t find DHCP when I try to connect
- NightCometAug 24, 2021TutorJust reboot it until it does. Look how long this thread has been going. Look at how many other threads on the exact same issue have popped up. Netgear doesn't give a **bleep**. Horrible product, 0 support. Okay going to unsubscribe from this now, better luck next time you buy a router everyone.
- 0Manny0Sep 06, 2021Initiate
Same, I personally won't be buying a netgear or dlink router again, if I hadn't decided to replace my RAX40 with a dream machine pro, I would have just bought a raspberry pi and used pi hole as a router replacement.
