llerrad321
Sep 16, 2020Aspirant
nighthawk ax4 does not recognize password on 5g
works password on 2.4, but does not on 5g
Sep 16, 2020Guru - Experienced User
Do you have the RAX40?
What device is having issues?
all of them?
Certain ones only?
Did you change the password?
Make sure to remove any special characters/spaces from the password.
Also make sure capitalizationj is correct.
llerrad321
rax35,works on 2.4,but not on 5g on all devices
- llerrad321Sep 16, 2020Aspirant
can i do a factory reset to make sure i didnt change any passwords
