llerrad321
Sep 16, 2020Aspirant
nighthawk ax4 does not recognize password on 5g
works password on 2.4, but does not on 5g
llerrad321
rax35,works on 2.4 but not on 5g on all devices
Sep 16, 2020Guru - Experienced User
have you tried changing the password?
check for special charaters/spaces?
forgetting the ssid/password on your devices and reinstalling them?
You're not giving me a whole lot of info. help us to help you and fully describe issues, what you've done to try to fix it.
- llerrad321Sep 16, 2020Aspirant
can i do a factory reset,and use the password that is on my router incase something was change
- plemansSep 16, 2020Guru - Experienced User
You can factory reset anytime you want. Its pretty simply. Push and hold reset for 7-15 seconds while its powered on. Then just reinstall it.
