llerrad321
Sep 16, 2020Aspirant
nighthawk ax4 does not recognize password on 5g
works password on 2.4, but does not on 5g
Sep 16, 2020Guru - Experienced User
have you tried changing the password?
check for special charaters/spaces?
forgetting the ssid/password on your devices and reinstalling them?
You're not giving me a whole lot of info. help us to help you and fully describe issues, what you've done to try to fix it.
llerrad321
can i do a factory reset,and use the password that is on my router incase something was change
- plemansSep 16, 2020Guru - Experienced User
You can factory reset anytime you want. Its pretty simply. Push and hold reset for 7-15 seconds while its powered on. Then just reinstall it.
