joeblackjack
Aug 03, 2020Tutor
Nighthawk AX4 Loses Network
My AX4 router has, more and more frequently, been losing the network. What I mean is, the WiFi stops broadcasting, and even if I connect directly to the router by Ethernet, I am unable to connect. Thi...
Lynnfield
Aug 05, 2020Aspirant
Last update: V1.0.3.80_1.0.1. How can I downgrade?
Aug 06, 2020Guru - Experienced User
to downgrade, you go to the support site for your device.
click on "downloads" then click on "+view previous versions"
download the version you want and extract it.
Then follow the manual firmware update process and use the firmware you downloaded.
to access support site go to netgear.com/support/ type in the model number.
- KelvinlawAug 06, 2020Aspirant
Thanks Guru, I follow your steps and get it done. I just downgrade to the previous version and hope the problem could be solved.
Thank you so much for your help! Much appreciate!
Thanks plemans, I follow your steps and get it done. I just downgrade to the previous version and hope the problem could be solved.
- LynnfieldAug 06, 2020AspirantThank you. Will try to downgrade asap.
- LynnfieldAug 07, 2020AspirantHi.
Cloud you please tell me if there’s an update coming soon? All over the www people are complaining about this. I think it’s a good router but software is very buggy.
Cheers
