joeblackjack
Aug 03, 2020Tutor
Nighthawk AX4 Loses Network
My AX4 router has, more and more frequently, been losing the network. What I mean is, the WiFi stops broadcasting, and even if I connect directly to the router by Ethernet, I am unable to connect. Thi...
Aug 06, 2020Guru - Experienced User
to downgrade, you go to the support site for your device.
click on "downloads" then click on "+view previous versions"
download the version you want and extract it.
Then follow the manual firmware update process and use the firmware you downloaded.
to access support site go to netgear.com/support/ type in the model number.
Lynnfield
Aug 06, 2020Aspirant
Thank you. Will try to downgrade asap.
