mfk5331
Jul 02, 2019Tutor
Nighthawk AX4 Randomly Stops Working
I purchased the Nighthawk AX4 router several weeks ago and after about a week of use I began having connectivity issues with it. It is model RAX40 with firmware V1.0.2.46_1.0.1. Everything worked...
ace115630
Jul 20, 2019Aspirant
I am having the same issue. Mine is related to DHCP. The router randomly reassigns bad IP addresses to devices. Changing my devices to use a static IP and configuring them properly solved the issue. Kind of annoying that this is happening but this is a workaround if you are having this same issue. Next time this happens, take note of the IP addresses on your devices before you restart the router. If they are completely wrong, change them to static and configure them and the device should work fine without having to restart the router.
mfk5331
Jul 22, 2019Tutor
How do I change device IPs to static? The only static IP setting I can find is for the internet. I'm really not sure how all that stuff works.
- ace115630Jul 22, 2019Aspirant
This would be done from each individual device unfortunately. Almost all devices give you the option to manually set IP settings. So no matter if it's a TV, a laptop, a smartphone, etc, in the process of connecting the device to a wifi network, there should be the option to set the IP address manually. If you're using default settings on the router, it's internal IP should be 192.168.1.1. On each device, set the default gateway to that address (192.168.1.1 if default settings), then set the subnet mask to 255.255.255.0 and set the device's IP address to something like 192.168.1.XXX (XXX = 100-255). The device should also ask for a DNS server. Just use the same address as the default gateway (again, 192.168.1.1 if using default router settings)
- michaelkenwardJul 23, 2019Guru - Experienced User
And once you have set the IP address on the device, you can tell your router to Reserve that IP address so that nothing else can use it.
The manual for your device will explain how to do that.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
- mfk5331Jul 24, 2019Tutor
I've found that my Nest thermostat and Google Nest Hub don't allow you to set a static IP. Is there any kind of workaround for that? Setting a static IP seems to have fixed the problem on my other devices.
