trenyak
May 17, 2019Aspirant
Nighthawk AX4 Range
I have the Netgear R6300 router (AC), I've had that for five-six years, and I'm thinking of replacing it with a Nighthawk AX4. My desktop has a Netgear A6210 (AC) so it connects at AC speeds, and my...
trenyak
Jun 23, 2019Aspirant
The link provided for the wifi6ax1650 module, that's for laptops only, right?
What module should I get for a desktop? I have a Dell Inspiron 570 desktop running Windows 10 Pro 64 bit.
regards,
Tom
schumaku
Jun 23, 2019Guru - Experienced User
Check the post above - there are two links, one to a Wi-Fi 6 module, one to an Adapter/Converter.
- trenyakJun 24, 2019Aspirant
Yes, there are two links, one for the wifi6 module for a notebook computer and the other link for the adapter/converter. Does this mean the adapter/converter is all I need for my Dell Inspiron desktop?
regards,
Tom
- schumakuJun 24, 2019Guru - Experienced User
Tom,
An available PCIe expansion slot, some luck, and the current Killer Wi-Fi 6 AX1650 resp. the AX200 drivers (depends of what you buy) direct from Inhell.
- trenyakJun 26, 2019Aspirant
thank you. I thought the Killer wifi6 ax1650 was only for laptops. What do I need to get for a Windows 10 desktop with a PCI card?
regards,
Tom
