Td17's avatar
Td17
Nighthawk ax4 RAX35 2.4 GHz not working
I can no longer connect to the 2.4 GHz network. The 5g is working fine. I have firmware version V1.0.3.62_1.0.1. From my understanding this is the current version. The light on the router shows green ...
  • Td17's avatar
    Td17
    Apr 27, 2020
    Thanks. The 2.4 GHz light was on. I ended up doing a factory reset. That solved the problem.
