TommyLittle1989's avatar
Nov 15, 2020
Nighthawk AX4: RAX35 can't run as Wireless Access Point mode
hi Support team, I bought 2 RAX35 devices, both of them are upgraded to latest firmware(Firmware Version V1.0.3.80_1.0.1) but just the 616197WKA54E6 device can run as AP Mode, the others can't(this device can't broadcast IP to clients that connected to it and clients can't ping to it too, but when unplug LAN Cable to device's WAN port, client can ping it). I've tried hard reset(factory reset) many times, restored backup of 616197WKA54E6 device's configuration to this device and already downgraded to original Firmware Version V1.0.3.62_1.0.1 but still get the same issue. Please help me troubleshoot this issue Thanks and Regards,
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello TommyLittle1989,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
