kkc2020
Jul 01, 2020Guide
nighthawk ax4 (RAX35) drops connection. multiple calls to 'tech support' yield nothing
i set up the nighthawk nightgear ax4 rax35 router several weeks ago. when it works it works very well, but it drops connection multiple times a day. i've literally wasted days on the phone with netge...
jreddout
Aug 12, 2020Tutor
Same issues here. I am on my 3rd new unit. Very frustrated here! We should not have to reset/reboot our routers everyday. RIDICULOUS!
kkc2020
Aug 23, 2020Guide
Don’t let them give you the useless beta firmware. It’s terribly slow and drops connection. Worst tech support ever and terrible product.
- jreddoutAug 23, 2020TutorOriginally I have purchased this router through Walmart. My 3rd replacement unit was brand new in the box. I took it back to Walmart without the receipt and they gave me store credit. Netgear is all JUNK! I have supported the company for 15 years. Support is garbage too! I took the money and purchased a TP-link AX3000. Reviews by Toms Hardware guide as the best bang for your buck WiFi 6 router. Glad I did working flawlessly! Dump the device and support a better product.
- kkc2020Aug 24, 2020Guide
i wish i had done that. i bought my device at walmart also, but i am outside of their return period now because i have spent these months on the trouble shooting.
i will make a note of your TP link recomendation, as very likely netgear will not resolve my issue.
