craigaroni
Jun 15, 2020Star
Nighthawk AX4 (RAX35) nonfunctional when changed to AP mode
When connected to my ISP’s gateway, my Nighthawk RAX35 router creates its own 10.0;0.x local network. I want to configure the router to instead extend the 192.168.1.x local network created by the gate...
- Jun 28, 2020
With the help of a Gearhead tech, after purchasing a support contract, two fruitless disconnected sessions, and a final 2 hour 30 minutes session, my RAX-35 is now working as desired...all wireless and ethernet connections have IP addresses on the local network of my ISP gateway.
AP Mode is NOT the answer; the tech agrees it SHOULD work and likely a firmware problem.
The fix: Connect an ethernet cable from the ISP gateway to an ethernet port of the RAX-35, not to the internet port. On the LAN Setup page (Advanced Tab), assign the router an IP address in the range of the ISP network and turn off Use Router as DHCP server.
Hope this helps others struggling to achieve the same configuraion. Seems common enough to warrant discussion in the manual.
craigaroni
Jun 16, 2020Star
Yes, the admin page for my ISP gateway shows the ip address assigned to the router, but the router admin page does not load using that address, not from the gateway's local network, nor from devices connected to the router via ethernet. (Devices connected to the router show a self-assign IP address.)
Jun 16, 2020Guru - Experienced User
once the RAX is in access point mode, do you have it connected via the wan port? or lan port?
The devices aren't self assigning. Somethings giving them the ip address. and if the RAX is in ap mode, it isn't the rax.
- craigaroniJun 16, 2020Star
Following instructions in the user manual, the ethernet cable is connected to the internet port on the RAX35, and to an ethernet port on the ISP gateway.
When the RAX35 was in AP Mode, I noticed that a connected device had an unexpected IP address, not from the 192.168.1.x local network of the gateway, nor from 10.0.0.x (as when the RAX35 is NOT in AP Mode). Recalled it said self-assigned, but may be mistaken.
- plemansJun 16, 2020Guru - Experienced User
have you tried to access it via the nighthawk app?
My recollection is that the Nighthawk app could not connect either; I'll try that when I get a chance to put router back into AP Mode.
- schumakuJun 17, 2020Guru - Experienced User
No idea why the RAX35 does get an IP. but not the systems associated (by direct connected LAN or wireless). Can't help much with discovering what's wrong with the AP mode ... I guess it's the last thing tested - if ever - when udating firmware. Kurt's law: Consnumer routers don't make good APs - avoid.
craigaroni wrote:When the RAX35 was in AP Mode, I noticed that a connected device had an unexpected IP address, not from the 192.168.1.x local network of the gateway, nor from 10.0.0.x (as when the RAX35 is NOT in AP Mode). Recalled it said self-assigned, but may be mistaken.
This is correct and normal - modern computer OS (Android, Linux workstations, iOS, MacOS, Windows...) revert to self-assigned ZeroConfig addesses if the BOOTP/DHCP process does not succeed and no fall-back/alternate network config is in place.
Needless to say that you can't reach your RX35 from devices with ZeroConfig IP addresses if it has received an IP in the 192.168.1.0/24 subnet from your router.
- craigaroniJun 28, 2020Star
