craigaroni
Jun 15, 2020Star
Nighthawk AX4 (RAX35) nonfunctional when changed to AP mode
When connected to my ISP’s gateway, my Nighthawk RAX35 router creates its own 10.0;0.x local network. I want to configure the router to instead extend the 192.168.1.x local network created by the gate...
- Jun 28, 2020
With the help of a Gearhead tech, after purchasing a support contract, two fruitless disconnected sessions, and a final 2 hour 30 minutes session, my RAX-35 is now working as desired...all wireless and ethernet connections have IP addresses on the local network of my ISP gateway.
AP Mode is NOT the answer; the tech agrees it SHOULD work and likely a firmware problem.
The fix: Connect an ethernet cable from the ISP gateway to an ethernet port of the RAX-35, not to the internet port. On the LAN Setup page (Advanced Tab), assign the router an IP address in the range of the ISP network and turn off Use Router as DHCP server.
Hope this helps others struggling to achieve the same configuraion. Seems common enough to warrant discussion in the manual.
schumaku
Jun 17, 2020Guru - Experienced User
No idea why the RAX35 does get an IP. but not the systems associated (by direct connected LAN or wireless). Can't help much with discovering what's wrong with the AP mode ... I guess it's the last thing tested - if ever - when udating firmware. Kurt's law: Consnumer routers don't make good APs - avoid.
craigaroni wrote:When the RAX35 was in AP Mode, I noticed that a connected device had an unexpected IP address, not from the 192.168.1.x local network of the gateway, nor from 10.0.0.x (as when the RAX35 is NOT in AP Mode). Recalled it said self-assigned, but may be mistaken.
This is correct and normal - modern computer OS (Android, Linux workstations, iOS, MacOS, Windows...) revert to self-assigned ZeroConfig addesses if the BOOTP/DHCP process does not succeed and no fall-back/alternate network config is in place.
Needless to say that you can't reach your RX35 from devices with ZeroConfig IP addresses if it has received an IP in the 192.168.1.0/24 subnet from your router.
craigaroni
Jun 28, 2020Star
- DaTruAndiAug 14, 2022Aspirant
Did this ever get any update or actual fix?
I bought 5 RAX35 and already had one RAX40 for the purpose of using it as an access point in various spots in our (wired) house.
It seems to block DHCP traffic for some reason and thus clients accessing the access point never get an IP address.
I am not entirely sure as I tried so many permutations, but when I had one RAX35 set to another RAX35 that switched its IP to 10.0.0.1 because of a conflict with the local network, then DHCP seemed to suddenly work - from the 10.0.0.1 RAX35 not in AP mode to the RAX35 in AP mode.
Unfortunately ATT prevents the main router to be set to 10.x.x.x/8 - so even if that would work it would not help me.
And yes, I actually need the wired ports.
