Voymetra
Apr 17, 2020Aspirant
Nighthawk AX4 RAX35 not letting Ring Stick Up Camera to connect
Aloha from Hawaii, The router I'm using is a Nighthawk AX4 RAX35 with firmware V1.0.3.62_1.0.1 I have tried to install 3 RING battery powered Stick Up Cameras to add to my 2 RING Wired Spotlight...
Christian_R
Apr 22, 2020NETGEAR Employee Retired
Hi Voymetra,
Welcome to the community! May you try disabling Smart Connect in the router's settings.
Christian
- VoymetraApr 22, 2020Aspirant
Thank you for your help, but I'm a newbie at this. I looked around my settings on my Nighthawk RAX35 when I opened my browser and I can't seem to find smart connect. Can you walk me through or provide a video or screenshots?
- Christian_RApr 22, 2020NETGEAR Employee Retired
Hi Voymetra,
My apologies, I meant traffic meter and not smart connect. I've included the user manual linked below and you may refer to page 60 on how to disable traffic meter.
http://www.downloads.netgear.com/files/GDC/RAX35/RAX35_UM_EN.pdf
Christian
- dba336May 10, 2020Aspirant
I am having the exact same issue with my Nighthawk AX4: RAX35 router. I have a Ring Stick Up Cam that I cannot get connected to the router no matter the configuration I try or settings that have been suggested. Has a solution been found for this issue?
