Knickerbockerbd
Nov 28, 2019Follower
Nighthawk AX4 RAX35
Does this router require a modem?
michaelkenward
May 14, 2020Guru - Experienced User
whizz wrote:
I have a plusnet modem,acording to instructions when I took delivery of my nighthaw I connect first with erthernet then reboot my nighthawk then use netgear genie or go to routerlogin.com,or routerlogin.net but for some reason I cannot bring the page up.
Plusnet, aka, BT, usually supplies modem/routers. (Does it do wifi and several Ethernet ports?) That is probably why your attempts to set up the RAX35 don't work.
If it is anything like BT's box Plusnet's thing is a pig that, unlike some modem/routers, will not play nicely in modem-only mode.
The easiest way out is to put the RAX35 into access point mode. The problem there is that you then lose some features.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But if your aim is to get decent wifi, it should work.
The Plusnet forum if there is one, may have other ideas.
In my case, I have several BT Homehubs that are still in their shrinkwrap. I had a D6400 Netgear modem/router but that didn't work well as the front end of a decent router. So I switched to a Netgear DM200 DSL modem.Sadly, these seem to have vanished from the market, although you can get "open box" supplies in the usual places. (DSL modem only devices are now hard to come by.) I bought one recently because I have a second DSL line.
whizz
May 15, 2020Aspirant
thankyou very much for your reply,still trying to get the nighthawk going will work with erthernet but not wireless but I will keep trying.
- michaelkenwardMay 16, 2020Guru - Experienced User
Well, which bit of the advice you received have you tried?
And what happened?
- whizzMay 16, 2020Aspirant
tryed netgear genie to connect to wirless when erthernet is connected but the minute I take erthernet out of my plusnet router and conect my nighthawk to my phone socket I get no connection at all I am trying to get online with wirelless connection
Sorry. But I am finding it hard to understand what you are doing.
Take this bit:
whizz wrote:
...the minute I take erthernet out of my plusnet router and conect my nighthawk to my phone socket I get no connection at all
If this Nighthawk is the RAX35 you can't connect it to the phone line.
The RAX35 is a router. You have to connect it to a modem that has its own connection to the phone line.
