stubs
Oct 17, 2020Aspirant
Nighthawk AX4: RAX35
So this model doesn't have a USB port. Readyshare is showing in the network lists. No way to 'configure' this in the router setups that I can see. Just how do I shut Readyshare off? Or is this ju...
- Oct 18, 2020
stubs wrote:So this model doesn't have a USB port. Readyshare is showing in the network lists.
Or is this just another instance of buggy software that seems to be the norm anymore.
If you see a DLNS or SMB file sharing server as it sounds like you are from the RAX35....
Then that would be very sloppy programming...borderline a bug, yeah. Short of possibly getting a custom config file to load, Netgear would need to address that in firmware, nothing you can do. :(
Oct 18, 2020Guru - Experienced User
So for this model, please post in the following forum:
Thank you.
