Angryasf
Jan 06, 2021Follower
Nighthawk ax4 rax40 setting up issue
So I've decided to buy a router and check it out and see how well it goes and what a freaking nightmare, downloads night hawk app proceeds through set up goes to login to router using admin and the de...
Jan 06, 2021Guru - Experienced User
I'm not a fan of the app setup. I usually recommend people use the browser based method. it tends to go smoother easier.
Try factory resetting 1 more time. Push and hold reset for 7-15 seconds while powered on.
Then connect a pc/laptop to the router and attempt using that method of setup.
