Retired_Member
Nov 09, 2019Nighthawk AX4 refuses Oneplus 6 after Oxygen OS 10.0 (Android Q) update
Since updating my OnePlus 6 to Oxygen OS 10.0, it's been impossible to connect to my Netgear Nighthawk RAX40 Wi-Fi router, whether with MAC address set as fixed or random. The password hasn't changed...
Retired_Member
Nov 09, 2019I'm not using "smart" or "easy" connect.
priyankm
Nov 30, 2019Aspirant
Hi,
I have a similar issue with my One Plus 6t. I recently bought the Netgear nighthawk ax4 wifi 6 router, and I am unable to connect my one plus 6t (Android 10) to it.
I could sign in from my wife's Samsung Galaxy s9.
- Retired_MemberDec 01, 2019
I've delved a bit deeper into the issue.
It appaears that the latest Oxygen OS 10 update on my OnePlus 6 device does not support WPA2 encryption over Wi-Fi.
If your router is cofigured with "WPA2-PSK (AES)" encryption, try downgrading it to "WPA-PSK (TKIP) + WPA2-PSK (AES)".
With this setting, devices that support WPA2-PSK (AES) will connect using this encryption and those that don't will connect using "WPA-PSK (TKIP)".
This worked for me while I wait for OnePlus to provide a proper OxygenOS 10 upgarde that supports WPA2-PSK (AES) just as the version 9.
- priyankmDec 01, 2019Aspirant
Thank you! Much appreciated, i shall try and let you know.
