Chadnado
Mar 31, 2020Aspirant
Nighthawk AX4 slow wifi speed
I have xfinity 600mbps wifi with a Docsis 3.1 modem hard wired into this modem. Running software V1.0.3.62_1.0.1 when doing a speed test wired I get 715mbps, wifi maybe 200mbps and the crazy thing is...
Christian_R
Apr 01, 2020NETGEAR Employee Retired
Hello Chadnado,
May you try disabling smart connect to see if that helps. You may also get in contact with our support team if you're still within the 90 days complimentary support period.
https://www.netgear.com/support/default.aspx
Christian
Chadnado
Apr 08, 2020Aspirant
That did not work
