gferraiolo123
Jun 25, 2022Aspirant
Nighthawk AX5 5 Stream AX4200 - Slow speed
OS 11.6.7 BigSur, Nighthawk AX5 5 Stream AX4200 / firmware is fully up to date. Every day I need to restart my nighthawk router and I believe the issue is the signal coming from my Apple TV. In the m...
Jun 25, 2022Guru - Experienced User
Optimum tends to use modem/router combo devices and not just modems.
what modem/gateway do you have from them?
- gferraiolo123Jun 26, 2022AspirantI just have the modem Arris. I should also say that this set up had been working fine for about a year and then it just stopped working. There was an outage in my area, which was fixed, but that didn’t help resolve the issue. And i updated my routers firmware hoping it would fix the issue, but it hasn’t.
- plemansJun 26, 2022Guru - Experienced User
What arris modem is it? They much a lot of versions
- gferraiolo123Jun 27, 2022Aspirant
Arris - TM1602
