Nanny22
Dec 03, 2021Follower
Nighthawk AX5 5-Stream AX4200 WiFi Router (RAX43) - Download Speed Issue
Hi, I have just recently upgraded to a new internet plan and was not getting the advertised speeds. On testing wired directly to the modem i was getting 700mbps download speed but wired into the r...
Dec 04, 2021Guru - Experienced User
If you just upgraded the speeds, I'd try factory resetting the router. Maybe an old qos setting is causing issues.
During the install process, leave qos, access control, traffic monitoring, and parental controls all disabled.
