Lee0
Sep 20, 2023Aspirant
Nighthawk AX5 AX4200 WiFi Router (RAX43v2) will not maintain internet connection
I just purchased the router to replace the original 7800 for parental control features. Installation was straightforward and quick. No issues, and the new router worked just fine for about an hour th...
- Sep 20, 2023
Take it back then. Try something else then.
Sep 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the top Internet LED turn AMBER when this happens?
