tecwerks
Sep 17, 2023Aspirant
Nighthawk AX5 RAX29 Wifi Printer always busy
Since install of the router every device I try and print from comes up with Printer busy message. It's driving me insane. The printer worked flawlessly on my previous wifi router. I do not know where...
- Sep 19, 2023
Received my HP printer with Ethernet port….happy to report that my printing issues are all resolved. Connected it to a Ethernet port on the router. Took me less than 5 min after opening the box. Time to throw my Brother Wi-Fi only printer into the garbage heap.
CrimpOn
Sep 17, 2023Guru - Experienced User
Does the printer appear on the list of Attached Devices (see page 99 of the user manual)
https://www.downloads.netgear.com/files/GDC/RAX29/RAX29_UM_EN.pdf
Perhaps the printer has a different IP address on the new WiFi network and devices need to go through the setup process again to "find" the printer.
tecwerks
The printer shows up on all my other devices. I’ve gone through the setups multiple times. NETGEAR tech support was clueless. It was a Saturday though.
