DarthWitten
Apr 13, 2025Aspirant
NightHawk AX5 WPS button
I am trying to add a wireless printer to my network. My router does not have a WPS button. Is there a way to use the APP to add this printer? Side note, I do not have an install DVD. The printer ...
DarthWitten
Apr 14, 2025Aspirant
It is a NighHawk AX5 AX4200 5-stream RAX43v2 router
Apr 14, 2025Guru - Experienced User
Most HP printers with wifi can be added by using on the board path to add the printer to any wifi SSID name and password. Refer to HP and there setup process and support information on how to add there printers to a wifi router using the SSID name and Password.
