Dirtnapper01
Dec 27, 2022Aspirant
Nighthawk ax5400 vs Nighthawk ax5300
What is the main difference between the Nighthawk ax5400 and t the ax5300? Thanks.
Dec 27, 2022Guru - Experienced User
Review the online spec sheets on NG download site to see what the differences are. Probably just a slight wifi speed difference is all.
- Dirtnapper01Dec 27, 2022Aspirant
I went through that and seems 1.5 core on both....and Memory: 256MB flash and 512MB RAM on AX5400 and AX5300 Memory—512MB NAND flash and 512MB
DDR4 DRAM, that's it??? I must be missing something.- FURRYe38Dec 27, 2022Guru - Experienced User
Probably that and check the wifi specs between them as well. Could be same or different.
