moresoup4u's avatar
moresoup4u
Nighthawk AX5400 will not connect to internet
Model: Nighthawk AX5400 (RAX54S)
I’m encountering an unusual issue with (2) brand new AX5400 (RAX54S) routers being unable to pull an IP from the ISP’s DHCP server. Please note that I’ve done the traditional/basic troubleshooting already (power cycle, factory resets, etc). This is something more nuanced than the ol’ off and on again can solve.
The ISP is a community fiber provider in a rural area, the only in-house equipment is a Power over Ethernet injector that provides the internet cable for the router. I have confirmed with the ISP that the customer can use whatever router they prefer. I’m currently trying to replace a Motorola MR2600 router. The internet works fine with this router. I can also directly plug my laptop in to the injector and it pulls an IP address fine.
So why won’t the Nighthawk? I have experienced the same symptoms with both (brand new) routers. It does work if I leave the old router plugged in and connect a cable from the Nighthawk to one of the LAN slots, so it can pull from DHCP on these routers (just not from the ISP apparently).
I have tried all (3) available firmware, no difference. (RAX54S-V1.0.5.106_2.0.70, RAX54S-V1.0.10.110_2.0.75, RAX54S-V1.0.11.112)
I’ve also tried cloning the MAC of the old router, setting a static IP, no help. Disabling the WAN security features on the router did not do anything (Disable Port Scan and DoS protection).
Anyone with ideas of what to try next? It seems to be a firmware issue, possibly security-related? Thanks for reading.
  • my experience: support was useless. I returned these routers and went with TP-Link AX3200s. they work perfectly. I appreciate the condescension! my recommendation: don't buy Netgear products.
  • plemans's avatar
    That POE injector is connected to something thats providing a connection. Do you know what it is? (model)
    • moresoup4u's avatar
      moresoup4u
      it's powering the fiber company's equipment, I don't have physical access to it.
      • plemans's avatar
        Ok, so you have a POE injector thats powering some type of gateway that you're connecting your orbi to.
        The goal is to figure out what that gateway is because some gateways, have their own routing features.
        And it causes a double nat. Netgear routers don't always place nicely with double nats.
