alex_rat
Nov 05, 2019Aspirant
Nighthawk AX5700 RAX75
I purchased the new RAX75 router from costco to replace my 5 month old night hawk x6s router. On my old router I was getting close to 150 thats 147 to be an estimate what im paying for. The n...
michaelkenward
Nov 06, 2019Guru - Experienced User
The new router getting 120 megs ....
How are you measuring those speeds?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
alex_rat
Nov 06, 2019Aspirant
Via Speedtest.net and night hawk app
modem is arris 3m3200
after updating the channels I got 149.81 up and 10 download megs wired connect
and WiFi 145-144 upload and download 9,81 megs
not sure if it's running properly before I buy the extend warranty from Netgear.
- alex_ratNov 06, 2019Aspirant
I mean 9.81
I'm running the latest firmware that's out.
- michaelkenwardNov 06, 2019Guru - Experienced User
That's what you think, but without a number we can't be sure (see above).
Not something I can find in Googleland.
How many LAN ports on the back.
Is that Speedtest.net wired or wifi?
The Nighthawk app is not a reliable guide.
- alex_ratNov 06, 2019AspirantOne wired and one WiFi
6 ports
