CptWelsh
Sep 22, 2022Aspirant
Nighthawk AX6 6-Stream AX4300 RAX45 WiFi Router
I have a Nighthawk AX6 6-Stream AX4300 RAX45 WiFi Router - Firmware Version V1.0.11.112_2.0.77, that I been having some issues with. I have a fairly active internet family. So i bought this router be...
CptWelsh
Just a little eccentric I guest. Setting each device individually kinda side step the DHCP. It would work for most of my devices. I know about the random MAC on Cell. I set them to use phone MACs. Any ideas on the pains that won't allow me changing IP's, Security CAM. And That wifi reaper/extender? (side note- I rebuild it. Works ten time better and cooler, bigger heatsink & fan, very poor design.)
michaelkenward
Sep 23, 2022Guru - Experienced User
I find it hard to understand that message. Take this bit:
How can you "set them to use phone MACs" if the MACs keep changing.
Or do you mean you disable the randomising?
Then there is this bit:
Can you explain that in ways that are easier to understand?
- microchip8Sep 23, 2022MasterThe Attached devices on that firmware version is buggy (I run same FW version). Here, devices will show up but the reported IP is often just 0.0.0.0. Sometimes a device will be completely absent from the list even though bthat device is functioning well.
All my devices use a reserved DHCP as I like a "fixed" IP for all my devices (easy to find/lookup them). So don't trust Attached devices this much and hopefully a new FW version will improve things, but with NG's/Delta Networks incompetent developers, my hope isn't high.
