CptWelsh
Sep 22, 2022Aspirant
Nighthawk AX6 6-Stream AX4300 RAX45 WiFi Router
I have a Nighthawk AX6 6-Stream AX4300 RAX45 WiFi Router - Firmware Version V1.0.11.112_2.0.77, that I been having some issues with. I have a fairly active internet family. So i bought this router be...
michaelkenward
Sep 23, 2022Guru - Experienced User
I find it hard to understand that message. Take this bit:
CptWelsh wrote:
I know about the random MAC on Cell. I set them to use phone MACs.
How can you "set them to use phone MACs" if the MACs keep changing.
Or do you mean you disable the randomising?
Then there is this bit:
Any ideas on the pains that won't allow me changing IP's, Security CAM. And That wifi reaper/extender?
Can you explain that in ways that are easier to understand?
microchip8
Sep 23, 2022Master
The Attached devices on that firmware version is buggy (I run same FW version). Here, devices will show up but the reported IP is often just 0.0.0.0. Sometimes a device will be completely absent from the list even though bthat device is functioning well.
All my devices use a reserved DHCP as I like a "fixed" IP for all my devices (easy to find/lookup them). So don't trust Attached devices this much and hopefully a new FW version will improve things, but with NG's/Delta Networks incompetent developers, my hope isn't high.
