Beckyj636
Apr 16, 2024Aspirant
Nighthawk AX6 6-Stream AX5300 WiFi Router
I have the AX 5300, With Charter Internet. The Internet is pushing at one gig From Charter, but the router goes consistently from 950 mbps to 500 mbps. ish.. Up and down like a yo-yo. If anyone has an...
Apr 16, 2024Guru - Experienced User
IF you can get a model# off the ISP modem, would be helpful.
This happen across multiple connected PCs or Laptops?
Possible if this had been working for a while, something on your devices may have changed?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Beckyj636
Apr 20, 2024Aspirant
Model number is ET2251
And all those features that you had suggested are in have been disabled
- KitsapApr 20, 2024Master
For consistency, recommend you use the Ookla stand alone testing application available from the play stores. Install the program on a computer and connect the computer to your router with an Ethernet cable.
This test setup avoids any of the inconsistencies associated with testing through a web browser or over Wi-Fi. The Ookla program also keeps a good historical record of the results.
Even with the Ookla application, real world test results can vary by plus or minus 15 Mbps from test to test.
Have you tried the internal throughput test option available in the Nighthawk mobile application?
- Beckyj636Apr 20, 2024AspirantI did here is the last set of results.
- FURRYe38Apr 21, 2024Guru - Experienced User
Those results are well reasonable results for wifi speed testing.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
- Beckyj636Apr 20, 2024AspirantDo you know of any self diagnostics you can do on these nighthawk routers?
