Beckyj636
Apr 16, 2024Aspirant
Nighthawk AX6 6-Stream AX5300 WiFi Router
I have the AX 5300, With Charter Internet. The Internet is pushing at one gig From Charter, but the router goes consistently from 950 mbps to 500 mbps. ish.. Up and down like a yo-yo. If anyone has an...
Beckyj636
Apr 20, 2024Aspirant
I did here is the last set of results.
Apr 21, 2024Guru - Experienced User
Those results are well reasonable results for wifi speed testing.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
- Beckyj636Apr 21, 2024AspirantThose results were the ones that came from the router that is hardwired. And it’s using the same site as you suggested. So those are not Wi-Fi.
- FURRYe38Apr 21, 2024Guru - Experienced User
The one attachment shows it being wireless.
What wired device are you using for speed testing?
Using Ooklas installable speed test on this one wired device? PC or laptop should see near 1Gb if you have this service with the ISP.
What speeds do you get with a wired PC connected directly to the back of the ISP modem?
- Beckyj636Apr 21, 2024AspirantThose were the results that I took from the Nighthawk app. When I ran the test, it was not getting run from my phone. It was getting run from the Nighthawk router itself.
