Maheil
Jan 05, 2024Aspirant
Nighthawk AX6 6-Stream AX5400 and Starlink
I am trying to replace an original Starlink router with a Nighthawk AX5400 router. I have the original Starlink router with Ethernet and no bridging. I thought I could just replace the Starlink box ...
Jan 06, 2024Guru - Experienced User
This user go his NG router connected to the ISPs equipment using a non managed switch:
I would review this and give it a try.
- MaheilJan 08, 2024Aspirant
That article mentions the newer router that has bypass and uses the Ethernet adapter. I have the earlier Starlink router.
- FURRYe38Jan 08, 2024Guru - Experienced User
Something you can still try. Or make contact with the ISP so they can help you out. Ask about a newer version of there router system.
Thanks. I don’t want to use the Starlink router though is the point (Starlink is the ISP if you will in this case.).
