Maheil
Jan 05, 2024Aspirant
Nighthawk AX6 6-Stream AX5400 and Starlink
I am trying to replace an original Starlink router with a Nighthawk AX5400 router. I have the original Starlink router with Ethernet and no bridging. I thought I could just replace the Starlink box ...
Maheil
Jan 08, 2024Aspirant
That article mentions the newer router that has bypass and uses the Ethernet adapter. I have the earlier Starlink router.
Jan 08, 2024Guru - Experienced User
Something you can still try. Or make contact with the ISP so they can help you out. Ask about a newer version of there router system.
- MaheilJan 08, 2024Aspirant
Thanks. I don’t want to use the Starlink router though is the point (Starlink is the ISP if you will in this case.).
- FURRYe38Jan 08, 2024Guru - Experienced User
Again, something to try and see if the switch will work, and you'll need to make contact with the ISP for additional help and information regarding getting a router connected to there equipment.
