Shiva3758
Aug 07, 2022Tutor
NIGHTHAWK AX6 AX4300 - Update error
I continue to get an Update Error when I try to update the router. Any suggestions on how to remedy? MODEL: AX6 AX4300 MAC IOS 15.16 HARDWARE VERSION. RAX45 FIRMWARE V1.0.11...
- Aug 07, 2022
Thanks for your help. Despite the prompts to update the firmware on the IoS mobile app, the firmware appears to be the latest available version. Appreciate everyone's input.
Aug 07, 2022Guru - Experienced User
what update error do you get?
Are you using the app or going through the browser?
Have you tried manually updating?
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Shiva3758
Aug 07, 2022Tutor
I am using App. I get a screen with image of product with header UPDATE ERROR. Bottom of screen choices are SKIP and TRY AGAIN.
- michaelkenwardAug 07, 2022Guru - Experienced User
Shiva3758 wrote:
I am using App. I get a screen with image of product with header UPDATE ERROR. Bottom of screen choices are SKIP and TRY AGAIN.Try the manual update that plemans recommended.
Ir is safer and more reliable than the app.
- Shiva3758Aug 07, 2022Tutor
I tried the manual update. Trying to download the update.
Got this message below.
The IoS APP says there is an update.
This process says there is not an update.
This is such a confusing process with Netgear. Thoughts?
Firmware Version CheckNo new firmware version available.
- plemansAug 07, 2022Guru - Experienced User
What actual version are you on?
You can compare your current version versus the one on the support site.
Nighthawk RAX45 | WiFi 6 Router | NETGEAR Support
